F3 hangs on boot
Important:
  • I had openPLI 6.0 on my Formuler F3 and yesterday I did update via GUI. After update device won't boot. It shows "Boot" on LCD screen plus green dot. The worst thing that I'm unable to flash even from USB. Tried different USB sticks and different versions but it seems that USB stick is not detected or system hangs on bootloader.
    Could you be so kind to advise how to solve such issue.
    Thank you in advance!
  • Format USB stick in FAT32
    Maybe try other images
    These nightly images are untested and may be faulty
    Viele Grüße / Best regards
    anmado :)
  • Online updates can sometimes be faulty, only one data incorrect and the system want work. Take older USB Stick 4gb or so, format this with Fat32 (standard not quick format!), copy image on it, rename the file "noforce" to "force", plug in, disconnect ac power and start the box. If Usb Stick recognised the update will start automatic, after install and before first reboot you need quick pull out the USB Stick, otherwise the Box will install again.
  • Thank you for the replies!
    I've tried with factory image and "force" without success. This USB stick was used to flash current box and F1 so it works for sure. Is there any option to recover box via RS232?
    Update: on screen message don't change. It shows only "boot" and green indicator
  • Solved by installing modified bootloader and flashing new image afterwards. As I was unable to find original bootloader it would be greatfull if someone can provide download link for original one because modified boot loader is still in beta.
  • Thanks for the feedback and notice
    anmado :)
    Closed the thread.
