Kodi Sound Test over Hdmi Report
  • Im will be running a sound test via kodi will leave report on what works tonight
    Im using the Shitty Build of Kodi,
    What worked
    Audio Channels Two
    Dolby Digital On
    Encoding On
    Dolby Digital Plus Off
    DTS On
    DTS HD off
    True HD off
    tested using the following clips
    http://kodi.wiki/view/Samples
    Dolby Digital Plus 5.1 (M2TS @ 1080p/29.970) (thanks wesk05)
    Dolby Digital Plus 7.1 Channel Check (MKV @ 1080p/29.970)
    Dolby TrueHD 5.1 (use clip #10 in 'Codecs' section below)
    Dolby TrueHD 7.1 Channel Check (MKV @ 1080p/29.970)
    Dolby ATMOS 'Amaze' Demo (M2TS @ 1080p/
    DTS-HD HRA 5.1 (MKV @ 1080p/23.976 VC-1)
    DTS-HD HRA 7.1 (MKV @ 1080p/29.970)
    DTS-HD MA 5.1 Channel Check (M2TS @ 1080p/23.976)
    DTS-HD MA 5.1 24-bit 192kHz audio-only sample (MKV) (thanks HomerJau)
    DTS-HD MA 7.1 Speaker Phase (MKV @ 1080p/23.976)
    DTS-HD MA 7.1 'Dredd' Audio Channel Check (M2TS @ 1080p/23.976) (thanks looun)
    DTS:X 'All Around Us' Demo
    MDR-HW700DS Decoder functions
    Dolby TrueHD Dolby Digital Plus Dolby Digital Dolby Pro Logic IIz* DTS-HD Master Audio DTS-HD High Resolution Audio DTS Express DTS Digital Surround DTS-ES DTS 96/24 DTS DTS Neo:X* Linear PCM 2ch/5.1ch/7.1ch * The Dolby Pro Logic IIz function and the DTS Neo:X function of the system support virtual playback from the headphones only. Virtual surround function OFF CINEMA GAME VOICE (STEREO)
    AFTER READING OTHER FORUMS, THAT RUN SAME CHIP PROCESSORS FORMULER They have got round the issue by creating kodi wrapper for there media player so if formuler can do that this will solve a lot of issues
    Edited 2 times, last by ians325 ().
