Power-off setting in Power Mode not Working
  • On my Z11 Pro Max, seeting the Power Mode to Power Off does not work. Still seems to go to Standby. Mytv starts playing the last channel almost immediately after CEC turn on by the TV. It is not booting up with the longer Formuler logo display start-up process as it did initially. I would prefer Power-Off mode if at all possible
  • Sam, I have Firmware Version: 11.3.3 Official installed. I tried changing Power Mode to Suspend and then rebooted. Then changed back to Power Off and rebooted again. The next time I shut down and started, it did seem to start up from the Power-Off condition. I'll monitor and see if the issue is really resolved. Thanks for your reply.
    Otherwise if it still exist. Do factory reset.
    Let us know please
  • Lucky133,
    If I do want to factory reset, I haven't found that the Z11 Pro Max has a backup and restore feature as some other models do. If there is a way to backup the device apps and settings, would you let me know where to find it ?? Re-installing all my apps, stored favorites and re-linking everything to Debrid and Trakt is quite a lengthy task. Thanks.
  • Lucky133,
    ???? Backup&restore function is in mol3menu>settings>scroll down (last one before the end)
  • woste,
    Thanks. That's what I thought -- just backs up mytv3. That helps a little bit, but the big workload is in the other apps like 'Sincler, Kodi, etc. If we get a couple of indoor-only weather days soon, I may go ahead and reset as the problem still persists. It's not a significant issue, so I may just live with it this way and manually restart periodically.
  • Interesting that when I manually change the setting for power mode to "suspend" and then change back to "power off", the next time it shuts down it works as expected (shutdown). However, after that first power off, it reverts back to "suspend" on shutdown -- even though setting is for "power off". So. evidently rebooting causes it to revert back to "suspend". Assume this is the Formuler Z11 default setting.
