Changing default Launcher
  • Is there anyway to set a default launcher on the formuler z7+ other than using the open app on startup function? In my case the TV Launcher app bought on playstore, I have it working as a launcher perfectly I just want it to be my default launcher when hitting the home button and not the box's own which is a little restricted. TV Launcher let's you add for example more than 3 sections and allows you to add shortcut [lexicon]settings[/lexicon] to the homescreen such as VPN etc.
  • Yes any launcher will work, but I want to set "Tv Launcher" from google play as the default home launcher i.e. when you hit home button. If you run a launcher and hit the home button it takes you back to the default launcher that comes with the box.
