Channel List style using remote?
  • Hi
    i just saw this screen using OK on my remote, but now ican't find the way to call this menu...
    I thought it was the OK button, but i have no luck trying to call it again ^^
    Tbh, while i was on this screen i tried the other style and didn't see any difference. Maybe it's a not working feature.
  • Since ages ago, the standard way to show the channel list on any STB is to press the OK button on the remote.
    You can change which channel list style will be displayed when you press the OK button by going the MENU > Settings > Channel List style
  • Yes you're right but that doesn't tell us how you can use the shortcut for the switch like the screen in the OP.
