mine still aint working with or without vpn. it just keeps giving me error 7 or error 11 depending on if I try using a portal or URL
Posts by jmustermann
I tried using a portal and that also did not work. My login credential don't work only on the mytvonline2 app. I installed IPTV starter on my tv and tried it there and it works without any problems.
Thank you. I have just read the article on the portal and tried it out and now I get an error code 7. I have searched it and found out others have had similar problems about this same time last year after a software update. Link to the page.
I think the problem I am getting has to do with the new update. My M3U and username and password are working on every other place I have tried them on, but for the formular z8 box. Prior to the update, it worked fine. So could some one please look into what is happening?
I am beginning to feel like I bought an expensive box which is not serving it's propose. I need a solution, else I will have to return the box to Amazon for a refund.(Box is just a week old)
Thank you. I have just tried all the different codes. Unfortunately none work. Do you know if I have to change any thing in the "type" too?
I have double checked to make sure the URL is valid with my Provided. Also when I use the code on IPTV Starters app, it works fine. It has also been working fine until after I did the software upgrade yesterday.
After accepting to upgrade, I can no long connect to my playlist. I get the following error. Please help. I am new to this and I have tried different tips I found online and on this forum.
Error
m3u Error
Check m3u UR\
code:11
- Model: Formular Z8
- Retail Box or Provider Box: Provider Box
- Firmware version:1.4.60 alpha
- MYTVOnline 1 / MYTVOnline 2 version: v7.6.10
- Box connected with: Wifi
- Did you factory reset your device? and when?: Yes. yesterday. On starting the box, I must however update back to the say updated version
- Picture url (only https): Edited...
- Video download url (only https): NA
- What issue(s) are you having? After updating the software, I can not connect to my playlist
- What was you expecting to happen? I have done an upgrade before and I was expecting my box to keep working as before.
- What happened instead? m3u link stopped working
- How can we reproduce the issue you are having? Guild me through how to solve the problem
- What have you tried if anything to rectify the issue? : factory reset the box, tried changing the "type=" of the url link. Contacted my playlist provided
Username and password has been replaced with * in the url link.
