Also the US discovery does nit work.!!!
try to use vpn...
try to use vpn...
Right from the fresh hard reset and firmware update it does the loop thing again, see above. Changed HDMI cables, same. Is this RMA?
Please reply
seems like it should be examined...
How to access recording files and delete them? - Formuler Helpdesk
Video or photo will helpful to understand what you mean
Troubleshoot freezing/buffering/stutter issue on MYTVOnline
and factory reset, change HDMI cable?
I just tested with my SD card formatted with NTFS, and it works well.
- Does your SD card work well? / try to change
- Make sure that it was plugged well your SD card in the device and check DVR options again
Display MoreZ8 Pro Box 1.
Latest update fw v1.6.1 + mytv online 7.15.2
Portal xtream login with login and pw.
Pictures black, EPG works, restart dont help reinstall Mytv online dont help.
Tivimate works fine, picture and EPG.
Z8 Pro box number 2 works fine, no problem at all.
Phone works fine to, LTE 4G or on wifi.
Any ideas what it can be?
t
1. Try to change different HDMI
2. Try to use a different HDMI port
3. Factory rest
4. what do you mean exactly flashing on the app side? any photo?
Can't find swedish telia play, only can find estonia...
Record it with your phone and you can capture it in your video...
You can't but you could do it DIY
1. How to create your own favorite groups:
https://www.youtube.com/watch?v=aJWqrVdD0fE
2. How to re-arrange the channels in your favorite groups:
https://www.youtube.com/watch?v=H6rUj4GL2ro
oh i understood you wrong sorry, i read like you were using a "keyboard" to type.
use "Back" button and then the keyboard will go away. But that keyboard image is very unfamiliar though
I usually use <-> tab keyboard button , then it goes down, to connect button.
Also if you typed all the data which is better to type in keyboard, i just use remote control, which is much easier.
which language you have for setting?
You could sideload it using downloader app
get unlinked install downloader from Play store and use code 40869 > unlinked > Go to unlinked store using code 'formuler' > you could see apple tv there and download it
Once it is downloaded it and launch , go to home screen add it newly downloaded app
Jump internal > Change minutes
I go into the display settings and it is set to OFF, but I select off AGAIN and it then turns off the HDR.
You put it OFF > you selected again OFF > Then turns OFF
I think you explained wrong?
