Posts by futuro
I already did it. It was 2.6.7 version.
I don't have Google services on. Only use Formuler for IPTV.
The Surfshark application on the Market is only in version 2.6.7, but version 2.7.0 has already been released.
In the Apk Mirror there are 4 variants, but I can't install any. Does anyone know what the problem is? Can someone show me the correct version to install?
Hi
Netflix? Prime Video? Fully working?
If yes I will buy it 😊
It seems that here the subject Netflix is a taboo topic. When referring to Netflix nobody gives explanations about anything ...
Yes, without "/" it worked.
Can you test with API XC?
I have the same provider for the last 2 years. Favorites worked fine with API XC untill last Formuler update.
Good afternoon, since the last update I can't get a list of favorites. Anyone else with this problem? I can create the list of favorites, but as soon as I close the MyTVOnline app the list is empty.
Let me explain: I use the list by API XC and did some tests.
If I use the list via M3U I can have Favorites.
If I use the list by Mac Adress, I can't have favorites.
If you use the list via the XC API, you cannot get Favorites.
Can anyone test by XC API, please?
Thank you
