Thanks you both for your help.
Hi z11pronotmax,
I have done what you said, it's normal the logo key of Nordvpn is not show it anymore since i enable MOL3 in Split tunneling ?
Thank you for your help.
BTW, Expressvpn will be beter than Nordvpn for you ?
Hi z11pronotmax,
Nordvpn will enable only for MOL3 and wil disable outside MOL3 ? Because i enable MOL3 in split tunneling of Nordvpn, that's right ?
I did't know what split tunneling is, thank you for explaining.
Thank you for your reply.
It's already enable LAN on Nord vpn (Automatic connection).
Hello everyone,
I have probleme with my Network Storage with Z11 Pro Max (I have also with Z10 Pro Max same probleme).
I can mount my Network Storage manuel but if i reboot my Z11 Pro Max and don't mount my Network Storage on startup, i have enable "Reconnect on Startup".
Later i found out that my NordVPN unmount my Network Storage.
If i disable NordVPN on start, Network Storage will mount as normaly, but when i enable NordVPN than my Network Storage will unmounting.
Someone know about this probleme and what can i do ?
Is happend also with Z10 Pro Max.
My Network Storage is connect to Synology DS1819+
Sorry for my badley english
Hi Ben,
Merry Christmas.
I use the software "AnyDesk", it's free, it's works fine for me.
I hope that i have help you.
Irving
Hello Dean Mills,
Thank you for your answers, I understand better why usb flash drive and external hard drive as my Nas are against write permission.
Hello Pa1zx,
I don't have a problem with my NAS in writing to records, but only problem with creating or copy and paste the files to my NAS, USB key or external hard Drive.
I found a parade, I have installed on my Formuler Z10 Pro Max and on my PC, the software 'AnyDesk' and here is the turn is played.
So i can copy files from Z10 to my PC or Pc to my Z10 and it's fast, without USB Stick.
I hope that one day it will work out writing on a USB key, external hard drive or NAS.
Irving
In the other app 'AnExplorer' said 'Android storage permission is disabled', but how i do enable 'Android storage permission' ?
I have already activated the authorization for 'AnExplorer &' File Commander Manager & Cloud ', see pictures.
I Hope you understand my problem.
It's not only the usb stick, but also my NAS as an external HDD (see my first post)
Thanks for your help.
I like to create a folder or copy files to my network storage, USB drive or external hard drive with 'File Commander Manager & Cloud', there is the message 'Read only access'.
I gave permission, but seems not to work, at least I did it wrong.
Can you explain me how i must doing, thank you.
Ah ok, Thanks for your help Sam.
Have an nice day.
Hi everybody,
I bought Formuler Z10 Pro Max a few weeks ago and I cannot find the Samba settings to share the Formuler device folder with my PC.It works well with Z8, but Z10 Pro menu is more different than Z8.
Can someone explain to me how to enable / disable SMB?
PS even my network does not see my Z10 Pro.
Irving
