Can anyone help when im pressing any button on formuler z11 pro the remote is flashing orange and working intermittently I’ve replaced batteries and rebooted box aswell any other suggestions
Posts by Dpritchard1988
Looks like im not the only one then if anyone finds a fix please post
Thats not worked either mate but the reset has put google voice typing selected back on when i did factory reset
i enter the pin click ok nothing come up
nothing is connected to box rebooted uninstalled mol3 and reinstalled in aswell just incase cant do factory reset either
Ive tried all then options turnt one off turnt one on turnt both off still dont get nothing
Photos as requested
ive cleared cache data and even uninstalled mol 3 and retried no luck
any help would be much appreciated when entering portal details no keyboard comes up and when trying to do factory reset i enter pin but no other options after that
Evening can anyone help with the z11 pro when adding portal the keyboard doesnt appear to enter the details ive tried to do a factory reset aswell but when entering pin theres no option after
When you pause dd atmos 4k and start again audio out of sync.
have you downloaded audio optimizer and load that usually does the trick
Wont let me download it iptv download error
Yes no matter what you do it just boot up the same thing everytime
Ive done wipe data and factory reset no option for fresh no matter what i do just goes back to same page
Done wipe date factory reset but no set refresh
I upgraded from z8 to z10 pro max,the z10 is alot faster than the previous gen,portals load alot quicker and the ui is alot more smoother
i would of stuck with z8 i did the same and z10 is pain full of bugs and issues z8 was flawless
Ive got a gtv i havent used in long while but when i boot box up comes up with this no matter what i do it just keeps coming back to this page any help appreciated
Anymore news on updates for no channel fix on z10’s i no theres update due to be released any eta on that update ? Many thanks dan
No not using vpn this is on more categories not just sport aswell a clear cache and reboot brings them back and on same service different box ie z8 theres no issues with this
