Posts by sim
    MOL4 Beta Report:
    1. When you start a replay and try to jump to a specific timestamp, it's very very slow, unlike MOL3 where it is instantaneous.
    2. There is an issue in MOL4, as well as in some other apps (except Kodi): sometimes when you play a movie in Dolby Vision, it is displayed on the screen, and sometimes it is not, even though Dolby Vision mode is enabled, unlike in Kodi.
    3. When you browse and then start a channel, the buffer gauge is transparent. You need to press the back button and then the info button to see its status.
    4. It would be recommended to add the number of items in each group (movies and series), as you have done for channels's groups.
    5. As mentioned by a friend, it would be useful to have a button to update everything in one click for all providers.
    6. Minor remark: my box language is set to French, but some terms in MOL4 are poorly translated.
    That’s everything I’ve noted.
    Pas eu de reponse par rapport au point 1 ?
    C'est très lent
    Merci :smiling_face:
