Beiträge von sergiri
    OPENSPA 7.1.001
    What is new
    - [formuler] Switch kernel 4.10.6
    - Fixed EPG 7 days
    - Fixed MyTube, thanks to yan12125
    - Fixed channel list issue, where channels appeared as N/A
    - Fixed PanelExtra to solve N/A issue in channel lists
    - Improvements at Notifications plugin. Now you can receive notifications in your smartphone.
    - Kodi 17.1 for Formuler F1
    - MediaCenter improvements :
    • Added new Kodi style
    • Added backdrop picture at media list screen.
    • Now, movie name is the real movie name, not file name (is essential to have movie info downloaded with spzImdb)
    • Added choice to open on last used folder or always on folder /media.
    • Fixed hang when entry in MC and try to access to a network mount wich is not available at this moment.
    - Improvements at spzImdb. Now you can download a backdrop along with the info and film cover.
    - Improvement at Plugin Browser. Now you are able to sort plugins in list.
    - Fix aspect ratio on MoviePlayer at Vuplus (until now, movies played with MediaCenter, Dreamplex, KodiLite, etc. were played stretched without black bars) .We need your tests and reports)
    - New layout for enigma2 menus.
    - Updated italian language, thanks to @hall9000
    To report bugs :http://openspa.info/forums/rep…de-fallos-en-openspa.265/
    User : root
    Pass : openspa
    AVAILABLE FROM MAY 1
    OPENSPA 6.0.010
    What is new
    - New drivers [email protected] HD51
    - New drivers Vuplus Solo 4K, Solo2, Duo2 and Solo SE
    - Fix standby to stop tuners when box goes to standby.
    - Improvement in series TV recordings.
    - SpaNewFirms: Added option to leave skin you have in previous release
    - New Panel Extra OpenSPA, where you can do :
    • Download channel lists uploaded to our forum.
    • Download updated mhw_EQUIV.epg file.
    • Download satellites.xml, port.list, cccam.channelinfo,...
    • Look at hardware and software info
    - Added new options for skin MetrixJR
    • Added turquoise color
    • Added new infobar with information about transponder and bitrate in same infobar
    • Added new infobar to use with transparent zzpicons.
    - Minor fixes.
    User : root
    Pass : openspa
    DOWNLOAD
    OPENSPA 6.0.006
    What is new
    - FlashOnline improvements to use every mounted device (pendrive, hdd, microSD, etc.). Network mounts can't be used
    - Improvements in spanewfirm (Installation Wizard OpenSPA), now it's also compatible with multidevices.
    - Changes in Confluence and MetrixJR skins.
    - Improved EPG Movistar +.
    - Added stream port [lexicon]settings[/lexicon] and stream authentication for more security in spzremotechannels
    - Added new M+ equivalences
    User : root
    Pass : openspa
    DOWNLOAD
    OPENSPA 6.0.005
    What is new
    - OpenSPA installation images using Flash Online. It is a completely online method without PC. Notice : if you install any previous release to 6.0.005, when image starts FlashOnline will not be available.
    - Improvements in spanewfirm (Installation Wizard OpenSPA), now it's compatible with FlashOnline.
    - Improvements in spaMetrixJR, now you can also configure OpenSPA menu icons.
    - Added secondinfobar screen with extended information in MetrixJR.
    - Improvements in spzImdb, to make finding films information easier and faster .
    - Improvements in OpenSPA downloads module.
    - Fix TV series recording plugin for channels with name changed.
    User : root
    Password : openspa
    Note : Online update not available
    Download
    OPENSPA 6.0004
    CHANGELOG 6.0.004
    What is new
    - Fix Movistar+ EPG 7 days
    - Spazemenu changes :
    • Significant improvement in horizontal spazemenu performance.
    • Possibility to use your own icons in submenus and with your prefered dimension (ask in forum if you are interested in this feature)
    • Choice between horizontal OpenSPA menu and enigma2 OpenSPA menu
    - Improvements in password changer plugin
    - Improvement in manual channels searching (you can search various transponders without exit to main TV screen).
    -New features in spaMetrixJR. Added new infobar and channelselection for zzpicons (picons 420x240)
    - New OpenSPA zzpicons (available to download from SPA Panel)
    - Fixes in skin confluence (FlashOnline, CutListEditor, etc.)
    - Fixes for RTL28xxU in kernel 4.0.1 (Zgemma, Gigablue, Formuler, Mutant)
    User : root
    Pass : openspa
    DOWNLOAD
