I have no USB or SD connectivity.
I do not know if you understand me correctly. So once again when I put the box in a deep standby mode, after OSCAM starts again, decode the NORMALNE card. OSCAM LIVE LOG. But the image starts to cut about 10sec. and then go again and then back again and so round the whole round. Use and restart the whole enigma or turn off the electric plug, then it is all in order. I'm afraid I can not use this bug in the deep standby box. I can use the standby mode. On another forum, they wrote that it could do the drivers on the box? Thanks
Posts by stosun
i have problem with image openpli i tried 4,6,6,1 but on one it does not work. After shutting down the stb to deep standby and re-energizing, the image starts to cut for 10 seconds, then goes off and then stays all the time. It will only help restart the whole enigma. I use Oscam to read the card. I tried pkt Hyperion but with the same result. Do you know what the problem could be? Thanks
