Posts by wullboy
    I loaded the BBC Iplayer app last night on my z7+, but the remote would not do anything at all. is there something i need to do, to get the remote to work on the player..??? Thanks...
    Just had a trial using the url portal on my z7, and it worked, and i think [ don't quote me on it ] his panel was streaminy.... Most trial up to now, including my original subscription didn't work, but this one did....
    Could i private massage you m8
    Can anybody on here confirm that this works>>>
    You can try this although it didn't work for me as I think its a provider issue when IPTV is not connecting since EX went down?
    Formuler beta software released for Zx, Z7+, Zx 5G and Z7+ 5G
    MYTVOnline 1 : 1.9.82 BETA Hotfix
    WARNING:
    HowTo Install:
    Home Menu -> Cog.Wheel -> Update -> press "0227" -> Red Icon and Beta Test SW appear (right corner) -> Press Red Button -> Now is the Firmware and Software shown, press now "OK" button for install.
    The install process and reboot works automatically! Please don`t turn off the box or plug out the power supply, could damage the box. The reboot after update needs always much more time then usual, please be patinate and let the box finish the install.
    Change Log
    [SYSTEM] FIX: Cannot connect to certain portals due to HTTP redirection issue>
    Hi, i have to 2 portals on my box, and i want to go into one of the ,The problem i have is that 1 off my portals is not working & i would like to go into the other portal, how do i stop the 1st portal from automatically trying to load, because it is not working, it keeps crashing and telling me to try again, it just keeps looking this way, and i would like to try my other portal, but i have no way to get into my 2nd portal, because it is automatically trying to load the 1st portal , so how can i stop it from automatically trying to load the first portal, thus allowing my to load my 2nd portal..thanks...
    i see the " epg Loading " message on the top right hand of my screen, but as Noobystyle stated, i also have to click on the channel within a bouquet to start the epg showing, [ not always ?? ] and only then does it load the bouquet's epg, and also,sometime i need to scroll within that bouquet to i see it completely load the epg on the channels...
    No m8, i asked that same question about a month back, as i quoted the enigma 2 box can be adjusted to own needs, was told maybe future updates may bring it in
    Ok guys, im new to using a formuler z7 box, i have 1 connection for my iptv to run on the mytvonline app,[ portal 1]so, i now want to buy another connection as a back-up for the first connection, so how does this work, I know i will put the 2nd connection that i'm about to buy on the 2nd portals url set-up within the settings, but, how do i switch between connections [ portals ] to watch them, as i only have the 1 app [ mytvonline ] how does this work......sorry for the knob question....
    I'm wondering why there is not a lot of people shouting out for this, Recording one channel white watching another, is a MUST. i would have thought, But seems not ????
