Create a folder called "Wallpapers" and add your images there.
Posts by Mevi
Is your hdd formated to NTFS? Try using KODI.
Those channels are not allowed in favorites
Try with another provider , using same box since release without issues.
Formuler boxes are like Nokia 3310.
I don’t have the Z11 to test but you can check this thread -> RE: Z10 support for Harmony Elite Remote Control
via the OSD (On Screen Display) while watching a movie by selecting the subtitle menu or audio options.
Is it supposed to serve as the input button to your TV if programmed correctly?
You can basically program it with any button you like, try again it should work if you bring the remotes very close to each other. I also had issues but eventually it works after the second or third time good luck.
Why would it not work?
Just buy a monitor with built in speakers or a non smart tv, tv's are not even so expensive anymore as they used to be, why make it so complicated lol.
voices are very quiet, while background music or effects becomes excessively loud
Seen a couple of movies with this it's so annoying
Release an upgraded version of gtv with mol3.
Hi, Sorry i am new to this box thing, but what is xtream codes api? i use a portal URL, but no username or password is needed.
How to use MAC/ID portal, Xtreme Codes Api (XC) and M3U Url on Formuler Boxes.
I highly doubt that mol3 is going to be available for other devices. I remember it was exactly the same issue when mol2 came out. Would be nice though if they did, maybe not now at this point cause of marketing and stuff but surely in the future.
Install the new Formuler Remote app v1.2.8 and check if the problem goes away.
The new version is available in the Market.
Seems like it went away, nice work! Thank you!
I rather have Formuler stand behind the boxes they have already released and we end users own them. Make software enchantments to these newer boxes Z10 series and GTV rather than releasing new boxes every so often. Wondering if all bugs are resolved on Z10 Pro max etc.
I'm hoping to see an update to GTV and Z10 series with new mytvonline 3.
Anyone agree.
How they gonna make money then?
Keep Dreaming, Because Sometimes Dreams Come True
Do you have any bluetooth audio devices connected to the Formuler?
No.
Happens also when you open mol2 and press volume button.
