Catchup doesnt`t work yet with m3u playlist and MOL2, maybe in future. Until then create XC Api Portal with your m3u data, this offers catchup/Cloud Timeshift.
Posts by SAM
You did it with your nb. 10 and are on the list!
How did you set MOL2 and system language?
Please check this thread -> S Series Instructions / S Serie Anleitungen
Could you please save your current channel list on usb stick and delete on S Mini, start new channel search and then try again. Next step would be factory reset.
Did you maybe changed some settings or uploaded other channel list into the box?
I guess it was NA Distributor decision to deliver this rcu, please ask him in this case. All other country's become the rcu's like in picture from rick.
If the rcu interfare with the soundbar then you need newer rcu with changed codes.
Format with Rufus tool (check how to in articles Menu on Forum) and Ntfs format. Connect and reboot the box once.
This is not original Alpha rcu.
You wrote that already in first post. I`m asking about your set system language and MOL2 language on GTV? Change both to English and try again, my GTV shows the trailers.
Some TV power save settings activated? Must correct me, i remember long time ago had someone almost same issue and at end it was some TV power setting. Unfortunately he didn`t posted the solution.
Check also the CEC Settings on TV and Formuler F1.
I tried another app OTT Platinum and it is not working either.
Is your Provider working on something? Try with other protocol, XC Api Portal or M3U Playlist.
Ok thx. Will try to reproduce.
The user assumes any risk of ban in this case! This depends fully from your provider and permission. Formuler is not responsible for any bans in this case. Pleas check this first with your provider before you use this feature with your m3u playlist.Is merge possible?
Nordvpn is really good for Iptv and Formuler boxes.
And with less than 16 it doesn't disappier?
Do like in this how to and epg should load, of course fulfil with data from your existing url.
If you get M3U URL from your Provider this could look like in this example: "http://provider.com/get.php?username=11111&password=22222&type=m3u_plus&output=ts"
EPG XML URL should look like in this example: "http://provider.com/xmltv.php?username=11111&password=22222".
Many users don`t get the EPG URL from Provider, now you can build by your self the EPG URL and insert into Mytvonline.
Just change following bold positions with included from your existing M3U URL:
