Posts by Rmjoe
I was hoping this update would fix the issue with the provider 8000/c issue but I’m still unable to use this provider. Has anyone been able to use this URL 8000
Thank you mevi
Game controller mavi.
Does the formuler controller work well. I want to purchase a wireless controller that’s is compatible.
Hello I have the ipega game controller and the Z8 does not see it. I have downloaded the game controller and that didn’t help. Is there something I’m missing or it’s just the Z8 doesn’t work with this type of controller.
It seems that the issue for me is the URL 8000 does not work. I have used 8080 with no issues. The update did not solve my issue. This happened since the last update but this fix did not help. Anyone able to use 8000 URL
Just downloaded the fix but still my error 7 is there but only for certain portals.
True Den if I knew my portals wouldn’t work I would have not upgraded firmware.
I have the same issue I can not connect to my portal since the last update.
Hello same I have cleared the cashe and rebooted many times. I’m still not able to connect to my provider since the last update. I’m using the portal Mac
After this update I have lost the epg info.
After the last update one of my providers stopped working. After reaching out to them they said the service is working and not on there end. I have others working on mytvonline but the one which stopped is met main. I have put a ticket in, I have 3 other friends with the same issue.
Thanks Sean I will try it.
I have purchased the gigabit to USB as directed and my speeds increase to 93 but I’m still getting buffering on the mytvonline app also on the stb emu. I. Am using a android box on stb emu and I have no buffer or studdering. I guess I will leave it unplugged until this gets fixed.
I was excited to try this so I did a factory reset and reloaded my providers and it’s still buffering. I was hoping it would work.
I have noticed my epg doesn’t load on 3 of my servers. But I have noticed if I use the epg grid it loads up the guide page per page. Some info in incorrect.
Sorry to offend you and the coders since I am not one I can’t advise. What I know is I had no issue before the mytvonline app. I use 5 different service and some worse than others but they all buffer. I don’t have the answer or pretend to know but this is a forum where we can speak. I wasn’t trying to get under your skin and if so forgive my ignorance.
Joe
