Posts by Lucky133
Unlikely to happen.
If it comes it should be a paid version😉
go to formuler remote app on your box.
i hope you got the bluetooth remote, if yes, choose the first remote on screen.
Then follow steps on screen.
Download from page: https://nordvpn.com/nl/download/android/
Or direct download apk:
Thank you very much for your interest. I tried maybe 20 times.. When I back to home, I can record a video when I do it. It never looks green light on the box.
Can you help me to find true usb method, which files I must download to usb? Maybe Usb hard reset work, I found a link and downloaded it but I am not sure if it is true files
i did it with my z7 last week.
Powercord out,
Power cord in
Then fast pushing for 10 sec on the red button on your remote. And then push 1.
maby you can also try it with 5 seconds.
Keep trying my friend. It really works!
YES it has been the IPV6 solution.
Ipv6 off or on?
just for sure😉
So your internet provider or router use only ipv4 or ipv6 ip addresses.
Happy for you my friend it works now.
thanks
resetted by the privider
working
Thank you for your feedback.
have a nice day.
Its ok thanks
I have restart the box and all is ok👌
Great news.
Bonjour,
Depuis la dernière mise à jour, kodi ne fonctionne plus..... : "ce package kodi n'est pas compatible avec votre appareil (néon).
Veuillez consulter le wiki Kodi Android pour plus d'informations..."
Pouvez-vous m'aider s'il vous plaît.
Merci.
English only please.
Apple TV Version 14.1.0
Formuler Firmware Version 11.2.10 Official
I send you conversation. So you can try the next step😃
Let us know it helped.
Good luck, hope it helpes.
i think my idea was the solution with the ipv6. 😜
Cause he didnt had internet till today.🤷🏻♂️
But hopefully he answers fast for us, so we know.
Can you have a look on your box at the menu for ipv6?
Just try it with ipv6 "on" and then click on dhcp.
Restart device.
If no internet, turn off ipv6 and then again lsub on "dhcp".
Restart device and try.
Maby it helps.
Formuler Z8 pro has only the radio stations available, no VOD or Series?
Unplugged and plugged back, samething
Button Groups, only radio.
What to do ?
Latest version dec,22
try refresh from menu.
In menu should it be, the vod or series.
Restart first.
Or delete mytvonline and install again.
Fill in your iptv credentials.
Test again. If radio appears again.
Contact provider, let them reset your line and check the tv channels, vod and series groups/bouquettes.
Are there more.devices at home what not work my friend?
Maby this version it not good enough.
maby go nack to older version?
try search for older version en try that? Maby that one works well.
Or wait for newer version. But can be weeks.
Many IPTV providers do not have countries other than your home country open, so if you go to another country, you must contact them and your provider open your connection to the country you want to use the box in.
Yes, but this time he dont have internet at all.
happy new year
Yeah, I tried a bunch of things. Removed categories from the portal, update, refresh, reboot, disconnect portal and reconnect etc and nothing seems to work.
Software bug.
maby they will fix it, maby not.
I had also found a little bug last year, what wont be fixed.
Hi there,
I have a question about the 'all' category in vod. I've disabled a bunch of categories in the portal and hit update. But when I go to the 'all' category, Content from those categories still shows there. Is this the normal behaviour?
Tested it yet on my formuler gtv.
You are right. Movie is still in group all.
I tested it with that was last week uploaded. It was only 1 title.
The movie was in de category "horror".
I disabled category horror and then update.
I refreshed also portal for tes. And yes, "horror" category was gone.
But in the group "all" the movie was still there.
It was last week uploaded so it was rhe firtst movie of "all" group.
Sow i saw it direcly.
I’m afraid it’s not. The first movie i wanted to test was 21 Jump Street.
The box correctly typed “21 Jump Street” no years no “-“ like previously mentioned, press “search” and i get the message “search failed”.
So i would not call this fixed.
And yes i made an fresh account on opensubtitles.com and logged in.
Dont start a search with numbers.
First text I though.
So after factory reset you also dont have internet? You tried dhcp button in menu?
Try other lan cable and other port on router.
Use wifi if you cant get connection due cable or broken lan port.
Any updates on subtitles. I am hearing impaired and have not been able the use my z10 pro for 5 weeks now.
Is there any other way around this opensubtitle issue?
We just have to wait.
I wait also for the mytvonline2 devices.
Install other app like nova video player or mx player.
you can search for subtitles with that app.
I have been using the Apple TV App on my Z11 Pro Max without any problem, then this week it stopped. Would not play anything. I tried to reset. No joy. Uninstalled and tried to reinstall but I cannot log in. Just goes back to main Formuler menu. I have the App working on another TV through a Firestick.
Which version you have?
I will have a look today.
Maby only you need the newest version or so.
Recently purchased the Z11 Formuler Box and when I go to the MyTvOnline 3 app, there is no "Menu" on the left hand side. It starts with "System Language" and includes other things like Subtitles, Parental Controls, Exit, About etc. But there is no Menu or Gear icon so I can't add a portal.
Please help
Delete it en reinstall mol3 via market?
Also did a refresh content?
So happy with my mytvonline 2 devices.
Z8 and gtv's.😃
You put on the device, and it starts mytvonline 2 and it connect to the portal and content, its direct fresh connection.
No extra work for refreshing content every time.
Why they make it manual refresh?
Why not automatic?
Why make formuler it not the same as in mytvonline and mytvonline 2?
When it connects to portal, you have direct the "new" content.
This is how i it see, my opinion.
I dont say "don't buy z11".
I only say its very simple in mol1 and mol2.
Hi, Where i can download the same File Manager apps for the Z8 Box? Thks for help!
I use file manager plus.
File Manager - Apps on Google PlayFast, easy-to-use and full-featured file manager app with cloud integration.play.google.comAlso to connect a network drive via remote smb.
give it a try
Thanks for that tip. I am able to see the upcoming program schedule on the channel I'm watching.
Now, if anyone has tricks on how to get the EPG back on my GTV . . .
I have a couple gtvs.
and on all work epg.
Connected with xtream codes.
and due time change last i had also epg.
But it wasnt synchronic. Changed it to "utc" and everything ok. Offset: 0
I own a Sony Bravia tv......yes it is old but the picture on it is great.
It has some good solid black.
Sony announced all tv's from 2011 - 2013 will not be able to run the Netflix app from febr 26 on.
Netflix app is blocked on the formuler box.
Anyone knows a workaround
......except for buying a new TV
Maby you get help.
maby not.
Its a formuler forum, not a tv forum😎
But i hope someone can help you.
What i know is that old tvs have ofcourse older android. Example android 5.
And netflix has minimal android 7 needed.
sow android 5 isnt supported anymore.
Refresh, you mean?
If it is what I think I did it.
Yes.
menu, then under vod and series should be refresh.
It fixed my problem.
Can you test it on other app?
if you have there image then i think you need to factory reset your device.
Fastest way is to reset your device.
Fill in your credentials in mytvonline and test.
sorry
No sorry my friend. I can everyone happen first time.
Contact provider, let them reset your account. Or maby set connection to vpn on there side.
I've read some posts here on the same subject but I tried everything and still no live TV.
I did factory reset, uninstalled the app etc, removed power etc, nothing works.
Do you have an ideas?
A refresh fixed at my side normally.
Just buy on official store.
I advice a formuler gtv cause of androidtv software.
All apps what you can use on your device are in the playstore.
No sideloading apps cause of good firmware.
In think you can search on amazon, ebay?
Maby you now official store in canada?
Bonjour .
du jour au lendemain je n'ai plus reçu d'images. J'ai réinitialisé mon modem et le formulaire. Je mets l'adresse du portail. connectez-vous et passez et rien. il est bloqué sur 5% de chargement.. quelle pourrait en être la cause..
English only please
hi all,
i have recently installed the bbc iplayer app on my z8 box and my laptop.
it works fine on my laptop but not on my z8 box: the screen is frozen on the home page.
i have tried un install then re install but with same result.
any help please
thanks
chorizo
z8 is android 7 my friend.
Bbc i player is for android 8 and higher.
You can try download it and install it from a site. But its highly possible that is doesnt work.
But ok.
Open website:
BBC iPlayer APK downloaden - Laatste Versie 2024BBC iPlayer APK downloaden en installeren - ✔ Versie: 5.6.1.30551 - bbc.iplayer.android - BBC Media App Technologies - App voor Android 4.4, 4.3, 4.2, 4.1 /…apkcombo.comClick above on on website on the tab: APK VARIANTS.
The look at tab: Android TV:universal
Then download the apk file.
Goodluck my friend
