Posts by hdr
Tested and the cloud timeshift starts at the beginning of the current program. Can not reproduce your issue.
Tested but was not able to reproduce reported. Done 4 recordings, gone to Recordings, long press on second , shows all four recordings for check and still marked is the one i did choose with long Ok press. Can not see any issues, marked stay marked.
Btw: What do you mean with cursor, mouse cursor or marked?
Yes, i meant marked.
So it's just me...
A little bug in recordings: when you have 2 or more the same day and you click for example on the second recording (to erase it), the "cursor" always moves to the first recording. You have to move to the recording you want to check.
New: it works (xc obviously) with a vpn...
So, it seems it's my router which is the guilty but i don't understand what it blocks from now on (i tried firewall off and it's not working)...
Edit 16 november: my ip was banned but my reseller didn't see it. It works fine now.
You reseller can check that.
I haven't a vpn installed and i always close mol before i shut the box.
I have no error, it stucks at 10% or if it connects, i have a black screen.
I disabled it and no change.
I really don't understand what happened...
In connection sharing with my smartphone, the server works.
I put DMZ on my Z8 but it doesn't change the result.
Another strange thing, I can't put a static ip on the Z8, it loses the connection; only the dhcp is working...
Edit: it seems it's unnecessary to put a static ip in router and z8: only in router ?
Following the beta update
It is not possible to delete a recording ...
I have to exit the menu and come back to delete a recording
Stalker
Me too (xc).
No ipv6.
But if mac adress is blocked, i should connect on xc but no...
i test my account on another formuler (xc) and it works (same account doesn't work on my Z8 while it worked for years).
I reboot my router 1 million times.
It stucked at 10%, no error; sometimes, it connects but black screen.
Box connected (other subs are working).
mac adress not banned dixit my reseller and it won't explain why it's not connecting on xc or with another account of the same subscribption.
I haven't changed to wifi, the subscription is working on another box on ethernet.
Really weird...
I installed the latest beta but no change.
I have a strange problem since this weekend with my Z8.
I can't connect since Saturday to a server I've been subscribed to for a long time either in stalker or XC. Either I'm stuck at 10% or I'm connected but black screen on everything (no VPN installed).
The account works normally on smarters on my shield and other subscriptions i have work on my Z8.
Even weirder, the account works on another formula (in XC of course) in my possession.
I made a reset of the Z8 but without change...
Last thing: on my Z8, I tried a test account on the same server (in XC) and I couldn't connect...
I really don't understand what happened and my reseller too...
If you have a magic idea, I'm listening...
Same here for cloud timeshift for one of my sub (4 letters).
Perhaps the same sub as allsatboy.
No problem with my other sub (ok in mac and xc).
Allsatboy is right: we didn't notice that.
French Translation error in settings : "Timeshift : Activer ou désactiver le changement d'heure locale" should be replace by "Timeshift : Activer ou désactiver le contrôle du direct".
I notice another modification to make:
when you make a recording " créer nouvelle planification" ("create a new schedule" in english ), 2 things to change:
- Instead of " créer nouvelle planification", i suggest "créer un nouvel enregistrement"
- instead of "date d'expiration", i suggest "date de fin"
Thanks.
I have a problem: afr works with live tv but not with vod.
I rebooted, cleared cache but no changes with two different subs...
I still have an erratic behavior with AFR: sometimes, i have "unsupported" in 24hz or even 25hz.
I resetted the Z8 a few weeks ago (not only for AFR) and it worked.
But, i don't want to reset regularly...
Clear cache and reboot not work this time.
