Hi all,
I have this z7+ box for a few weeks and facing the following issue:
If I use my box connected to my WiFi, mytvonline works fine and all my channels work perfectly (very seldom I couldn't detect any buffering). I have done a speed test it goes up to 10Mbps.
However, when I connect my box to my router through ethernet cable, all the channels starts buffering and it doesn't work anymore. I have done a speed test and it goes up to 90Mbps. As soon as I remove the ethernet cable, channels are back to normal.
I also found out that when I connect the ethernet cable, it seems that both WiFi and Lan connections are working. Is this normal? I tried to disable the WiFi after connecting the lan cable but same problem (channels buffering).
Any idea? Any of you faced this type of issues?
Dav
