hello friend sam, I tried to do what you told me, but it didn't work. my box gave a sign of life, but it made me flash the red and green light on my box several times and on television it gets several risks and turns off again. is there no solution? thanks
Posts by sarron
Hello friend SAM, I will try to do what you told me. it may be my solution if it works. I come here the forum say. 1 big thanks
Hello ,
I think my box died? I would like to know if anyone has a solution for my problem, I was watching TV and the picture blocked and I restarted my box and on my television signal that recognizes the box, but it does not appear red light in front and does not reboot . can anyone help me? thanks
Good morning, I installed the reset firmware, I installed everything as deser. and I put the lines cccam as it should be and I can not open the channels. It will be possible for someone to help me on this. Thanks
