Folder Properties in Windows only shows Files size on disk, but not available free space.
I can still copy files up to <1G to the USB attached to dreamlink
I have a USB drive attached to Z8. It is formatted as NTFS and has a lot of free space.
MOL2 can create recording files 3G or 4G large.
When I tried to use Window 10 to copy files larger than 1G using samba, it erred with "There is not enough space on share. You need an additional xxx MB to copy these files".
There was no error when copying files less than 1G.
Anything I should change to remove such limitation?
changing portal/playlist do not clear all scheduled recordings.
search for program name
hi
When I press the 'Record' button during Live TV, I can modify the default end time and extend/shorten the recording time.
But if I record a future program using EPG, is there any way to extend the record end time rather than using the scheduled end time from EPG??
Thanks.
Junk man
hi
If I put Z8 and Z7+ side-by-side, is there any conflict in IR remote? Can each IR remote control the correct box?
Thanks.
junkman
Thanks SAM for your response.
Due to similarity (especially recording feature) with Dreamlink T2 prime, if I purchase Z7+ and Dreamlink T2 instead, can I avoid IR remote conflicts in these two boxes??
thanks.
junkman
hi ALL
I am thinking to buy two Z7+ boxes and put them side-by-side to watch/record different channels at the same time.
How do the two IR remote behave? Will they still control the corresponding box without any conflict?
Thanks.
junkman
