Well changing the protocol was not the solution!
Still buffering....🥲
I have played around a little bit with the VPN settings.
Have changed the protocol from automatic to manual
Here are the diferent results:
IKEv2: 25Mbit
OPENVPN/UDP: 18Mbit
OPENVPN/TCP: 14Mbit
Shadowsocks: 23Mbit
Wireguard: 31 Mbit
Without VPN: 42 Mbit
So I will try with Wireguard and see if there is any difference when watching
Hi again,
Thank you for the support.
I have done following: took a new IPTV provider without VPN. Get 3 bars and no buffering or freezing.
When turned on VPN I only get 1 bar or no bar and watching is almost impossible
So it seems to be The VPN service but it is a well known VPN provider so i am still wondering
Additional: it is a router, with a built in Sim -4g. Have not found the original Model from ZTE.
Speedtest without VPN: 30Mbit
Speedtest with VPN: 12Mbit
What would you suggest: to buy a new router or use an other VPN service?
Thank you!
Bob
I know that this is not the best router. I get it from my internet provider.
I use a wired connection ( cable length is about 3 feet)
This is what I’m wondering about!
Hey Guys,
I really appriciate your support!
I have a router called B47E manufacturer is ZTE or Huawei ..see picture
Firewall is disabled
wired connection to Z8 - maybe a too old ethernet cable? Have ordered a Cat 7 one - waiting to be delivered
Only Z8 is useing this router and sometimes I connect my laptop via WIFI for testing
I use Surfshark VPN
I´m not sure if it is a router issue - because speedtest rigth now on Z8 shows me 11,3Mbps down and 16,4 Mbps up
It´s similar if I turn of VPN. No big change
Speedtest on my laptop: 71 Mbps !
If you say wired connection is better so could that big difference came from the old ethernet cable?
What reason could be when I change to static IP that youtube is not working?
Because of that I use DHCP
By the way what i additionaly recognized is the signal strength u see when wathchin live TV.
I always have one or none indication - never two or three! -> see second picture
Hope you can help !!!
Bob
I have now wired and static, wifi disabled ...but from time to time the „net“ is at zero ....see picture
Every time this happens ( every 2-5min) buffering starts
Tried a second provider-same issue
Any idea i could try??
Bob
6-7 Mbps to stream IPTV FHD - this propably depends form provider to provider
with my 15-20Mbit i have freezing and buffering from time to time so i thought with 50Mbit it should be better
I changed from DHCP to static - buit with static i cant watch series, even youtube is not working - so I changed back to DHCP
Thanks for reply. I do have a 5GHz antenna.
Which type do you have?
Maybe here are also differences!
Mine is rated with 1200Mbps-USB 2.0! 🤷♂️
Will also try with a Cat7 cable!
Hi Guys,
here is my problem:
My Z8 is connectet via 5Ghz with my WIFI. According Speedtest I have 15-20Mbit download.
Connecting my Iphone or Laptop to the same WIFI i get about 50Mbit according speedtest.
Do you have any idea or suggestions?
Thank you!
Bob
Hi
It would be great to export/backup the channel groups so you could restore them if needed (e.g. after reseting the box)
I asume that a lot if time is investet in these channel groups and al the work is gone after a reset
Thank you
Hi Guys,
My Z8 and my IPhone are connected with the same WIFI Network
When I make a Speedtest with iPhone I geht about 40Mbit
When I do the Speedtest with the Z8 I get about 18 to 20 Mbit
Because both are in the same WIFI i assume i should get same download ranges
Do you have any idea regarding Z8 settings I can adjust?
Thanks a lot!
Hi guys,
Today I started to use Surfshark.
Before (without) VPN everything works fine.
As soon as I turn on VPN I only gar a black screen or error 7 occurs.
I have a Z8 but the same is on my mobile withs a iptv app
Changing country and other settings doesn’t helped.
Could this be a provider issue?
Thanks for help
Bob
Is it any way to search in EPG?
E.g you want to watch „Darts“ or „Titanic“, is there a way to search in epg??
Thank you
Bob
Hi Guys,
i have done the molcfg reset and it worked but still no Portals to see
Z7+
any further ideas that i can try?
thank you
Hi Guys,
Z7+
thank you
Hi Mevi,
thanks for reply. Well it´s the same.....
How is your bitrate? Is it quite constant?
Need some help
Thank you
bob
Hi guys,
got a Z7+ with MTVOL and a WIFI connection with about 40-50Mbit download
When I change to an other channel in the very firts second I have a bitrate of about 22000kbps
then it dorps counstantely down to 1000kbps or less and the buffering starts
Do you have any idea?
Thanks for help
bob
i hab MyTvOnline Version 1.9.98
Have set it up some time ago
Everything works fine but I can’t where to edit the URL because in the Menu „Edit Portal“ Isn’t there.
If I press the menu button i see:
Live TV
VOD
TV Series
Settings
That’s all-> no PORTAL!!
Where can i find it??
Thank you!
I have connected my Z7+ box with my wlan and it works perfect (with 80Mbit 2,4 HZ, and 4 Mobiles and 3 LAptops connected)
But at my second home I have of course an other router.
This router delivers 150Mbit and is an dualband router (2,4 + 5G)
When I connect the box, it connects to the wlan - but I don´t get a picture !
I can add apps - so the internet works and the box is connected.
When I connect it with my mobile phone as hotspot ist works
Have also tried to connect via ethernet (same router) - no picture - only loading
But EGP works
I think it´s a router issue - but everything else workswith this router
thanks
xagentx
