After Upgrading 3 GTV devices, I find the units works better than ever. Have no issues with GTV whereas Z11 Pro has ongoing issues as noted in Forum.
Same here, no issues with my updated GTV 👍
Any news to ANY upcoming new products from Formuler??
The first GTV gets this month the androidtv 12 version.
There is yet no news about a gtv 2.
I want also a gtv 2. No more problems with apps. Everythings works.
Yes, it works, but I want MYTV3 (and AndroidTV) 😁
Hi!
Will there soon be a Formuler GTV 2 with AndroidTV12 and MyTVOnline 3?
Thanks!
When I’m connected to VPN, my EPG doesn’t work at all. When I disconnect VPN it works!
Any tips what the problem can be?
GTV update has been pushed back 1 month. Expect to release near end of February.
Ok.
What’s the reason? I see that updates comes for Z10. Is Z10 more prioritized?
Nonsense! It was planed to release Beta update until end of the year but the Z10 Hotfixes delayed this. Should come in Januar.
Any news when the new Beta will be available?
No updates for GTV for months! Is the development dead for GTV and Formuler only working on Z10?
Need to buy a new box. Which one is ”best”? GTV or Z10? Pros and cons?
Thanks 👍
Working as it should. Great update 👍☀️
Go to #116 !
SAM said…
Ok, missed that one No worries...
Not this Friday. Next Friday
Nope, should be today. SAM said: "This week ends on Friday!"
It's friday, yeeah...
The open beta was already opened with only 120 slots for users, all gone. Official should come next week.
Ok, thanks. Have to have patience then...
June 11 today, will the Beta be available for everyone today?
YouTube is possible and Amazon Prime and YouTube music, YouTube Kids.
2 ways to add them to Home Screen on GTV
Method 1) on the Home Screen where you see your current apps, press down on the remote control until you see “customise channels” and select that
Method 2) on the Home Screen, go to settings > device preferences > Home Screen
Thanks.
Yes I know of the methods. But the question is if I can add programs that I cannot find in the list? Can I add any software?
It is Android TV feature, shows preview from (in case of MOL2) max.16 channels. It was not programmed to watch live TV for longer, just preview.
Ok. But is it possible to add more services (ie. Spotify, Youtube, Netflix etc)? If yes, how? 😎
Thanks!
Nothing? Is it not possible to add channels?
Hi!
Is it possible to add more channels to preview on the Home Screen? Can see a few of my streaming channels today but not all and would like to be able to add them...
Thanks!
I don't have HDMI on my soundbar or bluetooth ... (maybe time to buy a newer soundbar ;))
Curious: how are you other guys connecting your GTV to external speakers to use Dolby ie? "A/V receiver that can connect to GTV's HDMI" - so connect your TV to the A/V receiver and from the A/V receiver to the GTV! Or?
Connect via Bluetooth to a soundbar that has that functionality?
Just want to know what's the best practice for best sound with the GTV
You only have SPDIF output to connect your woofer?
Yes (RCA connectors)
Ok, not possible for me. Thats a bummer and a disadvantage... 😔
I just looked and it does not have SPDIF output.
And how do we connect external subwoofer then?
Anyone know if there is a SPDIF output on Formuler GTV (like the Z8 have)? Cannot see it on any pictures I've seen...
Working perfectly with no problems at all 👍
Nice job 😎
Auto Frame Rate matching is really crisp and clear 👍
If I have the Formuler Z8, any advantages/disadavantages to upgrade?!
Please upload the screenshot from error message and text when it exactly happen.
See #3
I did a Factory Reset on my Z8, formatted USB stick according to your instructions.
Still get error message when doing Backup 😒
For me the "EPG Loading" is ok.
But I have turned off all countrys that I'm not interested in (only have 3 countrys and sports). No problems at all for me.
Connected to MAC portal
Anyone else that has problem when trying to do a backup? If I enter Restore it's ok, but Backup then the app crashes.
Is the epg loading also so long by someone?
No, really fast for me 👍
Getting a crash when trying to do Backup
Recording via USB works for me but it seems to start recording when I push Stop. When I watch the playlist and want to watch what I just recorded, it starts playing from where I stopped. Very strange, any ideas?
EDIT: it seems to start 10 sec after I start recording. Anything to do with Buffer Time?
When in June will the new beta be available?
So what happens when you press the power button on the remote to turn the device back on?
It turns on again, and the after 3 sec turns off black again
Yes and yes 😎 Same thing everytime...
Even if I don't try to open MOL2, it goes black
When moving my Z8 to a different network (from my house to vacation house, different network), box starts up, finds network, trying to open MOL2 and after 3 sec goes black!
Even if I turn off MOL, the box goes black.
Any idea what's the problem and how to fix?
Tried this a few times. Tried also a new box for another customer with the same problem.
Please take care of the problem with the software problem. I have installed almost 10 Z8 boxes allready and was very satissfied but this has to be solved asap. Or another beta release where the problem is solved. I do not want to install 3th party addons to make MOL2 work. It worked perfectly before.
Works perfectly for me. No issues at all (FW1.4.14 -SW 7.1.1)
