No issues with updates all working good
Exelent work Devs much appreciated on your hard work
Cheers
Cheers
Can't wait to get home today install and test
Thx for hard work Devs much appreciated
So what, was the issue
After update the app wouldn't start correct
So after many reboot the app started and working good
I'm at work will be later today home just trying to figure out the issues that I might have later today
Thx guys
Sam don't let one bed apple spoile the hard work you do
Keep up the good work brother
Cheers
If QA say Bugs are fixed should come, if not fixed and need to be done, then it will be delayed to next week. Plan for next week and be happy if it comes tomorrow
Reminds me when we where waiting for Direct TV fix, when will it be out lol
Thx brother, keep up the good work
Cheers 🍻🥃🍺
That's a great idea bud deffinetly they can look in to it and implement, but for now we have many more important issues that need to be fixed on this box.
Thx bud much appreciated
Cheers
Any info where is the next update coming to GTV
Do we have any road map when it comes to updates for GTV
Thx much appreciated
Cheers
Hahaha I know I don't get it but it's updated 😂
The only difference is on the top showing Disney plus couldn't finde option to disable or change
Everthing other looks same to me
I'll do it when I get home, not sure if it's official
I was doing some search about it and finde out that this version was, out on the 12th i believe
Just found new version of Android TV Home Launcher 3.0.10 the last one istall is 2.3.1
This is the link to apk ill change http to XXX so its not live link
The app works no problem and box is up to date
XXXXs://www.apkmirror.com/apk/google-inc/android-tv-home-android-tv/
Thx bud all good ,much appreciated
The first apk is Netflix Android TV (SD Quality)
Post 379
https://forum.xda-developers.c…349/page-19#post-84054575
Download to your phone then send to the box
Install app on, your phone send file to tv and install same app on your box and, you can send file no problem so easy
I got Netflix to work but quality not that great but it's ok to watch no issues no stoping but it's, definitely not 4k but I think it's HD
If some one can post how, can I check because pressing info not much info about it
Thx Sam much appreciated brother
Cheers
I use Netflix on my smart tv Ang get full 4k so deffinetly the less apps I have on my box is better
I only keep iptv app and that's all
All other Netflix, Amazon and Disney are on tv directly so I don't pound box with more garbage
I would definitely drain the lizard on that remote
Deffinetly if u can't get it to work, pack it up and exchange it brother.
Hope new box will be a breeze
That's strange for sure
I wish they can send u apk file for you to try side load the app and see if it works
I'm sure they have the apk file for Furmualr Update
