Posts by Netface
    Here is what I found on this issue with my Z7+ I cleared data & cache on MYTVOline reset the pin from 0000 to 1234 then back to 0000 every thing working oK to this point , then re-input port info load portal guess what the reset pin of 0000 fails to work again this is a sever flaw in the app itself I think which needs to be addressed. I even deleted the app and reinstalled same crap only way to use the xxx channels is to use app STBEmu Pro load the portal on that then 0000 works...... too Bad the Z7+ has so much potential yet fails in so many little ways it is sad :frowning_face::frowning_face:
    Did you ever get it to work? im experiencing th same thing
    there are bluetooth remotes i believe, that would have a dongle. i use the harmony hub and the IR blaster :face_with_tongue: but those both dont solve the wire issue. maybe hide the IR blaster nicley. mine is on a black metal post and inivisible. also the adhesive tape on the blater is good
