I also did that with my USB drive, then I set it as internal storage on the set-top box, but now in the settings I can't set it to record there because only the set-top box's internal storage appears. Can anyone help me? Thanks.
Posts by madmex
If you have a Formuler z12 ultra, don't update to MyTVOnline 4. After updating mine, it died. Nothing appears, just a green light on the box, and then it doesn't boot or anything...
It's working again now. I had to turn everything off – internet cable, USB, power cable – I unplugged it and waited a minute, plugged it back in, and it works. I'll give feedback later on whether it's worth upgrading from MyTVOnline 3 to 4.
I think it's best not to update to MyTVOnline 4. After updating on my Formuler z12 ultra, the box is dead; the green light comes on, but nothing happens. Just a black screen.
Hi, it transfer your playlists, favorites...and at the end MOL3 is the only app which is gonna be deleted. Do no way back!
All other apps are still there.
Have a nice day.
Hello everyone, does anyone know if updating to MyTVOnline 4 deletes all other installed applications? Or only update to MyTVOnline 4 and keep all other applications installed on the box? And what about installed playlists, it keep them or delete them as well? Thank you in advance to anyone who can answer these two questions.
