Posts by stegini
    I left my box unplugged for the night to see if that would do anything,
    It’s stopped just the once today. So a massive improvement on it stopping every 20mins or so.
    I haven’t changed to static ip yet just to try everything first.
    Do you think leaving it unplugged would have done anything beneficial?
    Cheers
    Lol sorry mate, I’m not very clued up when it comes to this sort of thing I’ve never had a problem because it runs immaculate normally 😁
    It’s m3u playlist
    Z8
    Ethernet
    Others subscriptions apart from mine are working fine with exact same build and also beta updated
    Thank you for moving thread, I didn’t have a clue where I was posting it as I haven’t long joined the forum, sorry about that.
    I don’t think it is a problem with the provider as other ones are working fine. (Z8)
    It’s been brilliant ever since the last few days, I noticed it first watching 24/7 tv programme and it just froze and then I couldn’t access anything else.
    Do you think it will be resolved when I next update?
    I updated using this beta today because I was having problems with ‘Failed to load VOD Data’ error in movies and also in tv shows.
    Live tv is just a black screen on every channel when this happens.
    I then have to disconnect portal and reconnect in order to fix this problem and everything seems ok again.
    After the using the beta the problem still persists,
    Is anyone else experiencing this problem or knows what I can do?
    I’d appreciate any help thank you
