Does not work on a rooted Pixel 9 Pro.
I respect your decision to block rooted phones but I prefer to uninstall the app rather than change my phones settings. It was good as long as it lasted.
Thank you
Thank you
Working fine on Pixel 8 Pro. Thnx
Sorry SAM, I moved it because the thread said "Solved" and I didn't know you moved it...I thought I did not delete it. Thanks for your understanding.
1 Z8 and 2 Z8 Pro units exhibit the same black screen mentioned here.
Everything works fine (VOD, TV Series, Radio, EPG) except Live TV. Tried with and without VPN.
Factory reset done but still nothing. All 3 were working fine and checked the same provider on another brand and works fine.
deleted the / from the end too without success.
Any ideas?
Thank you
1 Z8 and 2 Z8 Pro units exhibit the same black screen mentioned elsewhere.
Any ideas?
Thank you
