Posts by ibzy123
    After reading the review of Z8 I purchased one and i'll never look back at any other IPTV Box ever again as the Z8 is the King of all IPTV Box out in the market, its easy to use and setup for a newbie. Defiantly user friendly IPTV app "My TV Online 2" which works great, and the bonus part you can record your own programs and shows and the picture quality awesome can't fault it in anyway, and can install other apps as well. The best to part it has OTA updates so your not missing out on the function to me that means reliability and money well spent. The support is great and get your Z8 back running again in no time & thank you for reading this post
    Desired No 21
    Since my Z8 asked me to do an update which i did to this version the ethernet connection works for few hours and then it stops working at all & I use Wifi to view IPTV. I have also tried to use Static ethernet connection which works for 15 min and then cuts off and cannot connect again. I have already logged on my router settings and switched off IPv6 settings and removed port forwarding still no joy on VM router settings. I have reset my Z8 twice after a few a day it runs smoothly and then ethernet cuts off.
    I am aware that I cannot roll back to the previous firmware
    I am with UK VM (Virgin Media) and i've never had issues with there connection as I have 100mg connection - is there a new fix to make sure that the ethernet is working. My router is close to the Z8 and its direct ethernet connection with a small ethernet cable still not connecting or recognising on the box? I have also swapped the cable still same.
    Previously this was working with VPN. I have tried to use this with VPN on and VPN off. When I connect to VPN it states connection in coffee break, and unable to connect too VPN on ethernet.
    Can you please help me with this issue with Hard wired connection for Z8 as this update has got a bug relating to Ethernet connection, as I have not had an issue since Z8 was new and paid allot for a reliable IPTV box with recording function.
