I found something that might help.
I opened the log files of the Fritz router and maybe I found the reason why the login of the Z8 failed.
Apperantly the Z8 tries to connect with a kind of guest user name, but why ?
Thanks for your reply but unfortunately this doens´t work out as well.
I´m not quite sure but maybe it´s related to one of the latest released updates.
It worked until then properly.
Hi folks,
I desperatly tried to connect the NAS of my Fritz router with the Formuler Z8.
I have already read the Howto to this topic and did several google searches but nothing helped at all.
My situation:
It seems that I am already connected to the Fritz NAS but if I browse e.g. with the file manager it shows the message
"Login the server failed"
I think I gave the Z8 all needed permissions in the router (folders, read and write rights). I also tried static IP and DHCP.
The path in the setup should be ok, otherwise the z8 would not show the connected symbol, right?
The login data should also be ok because I am able to access the NAS with a win10 PC in the same Home Network.
I would be very pleased if anyone has any ideas ?
