I will try factory reset.
Posts by Robin45
Tried that. Not working.
I can’t get pcm 5.1 audio from my z8 to receiver. The source is 5.1, for example iptv through mol2 or plex. I’ve searched this forum, done as instructed , installed addons but nothing worked. Any suggestions?
I did a factory reset. Had to install everything again. Quite some work. But now it works well again.
I still get this problem. Is it something about the standby mode? Should i choose turn of instead? The one thing I can think is happened is that the power to our building went off. If that did something to the electronic. Something who broke on the box or the Router. The router workes fine with other devices.
Thanks for quick reply. I will try this.
I recently got a problem with Ethernet on my Z8. After a standby mode on the box something happens. The speed is very low so the IPTV doesn’t work. I have to restart the box and then it will work ok until it goes in standby mode again. Anyone who can tell me what the problem is? Router or Z8 box?
I an wondering if you use VPN on formuler z8 and if you do can view 4K movies.
I can’t view 4K movies VOD in MOL2.
How can I update my m3u file? In an app I use in my phone I just refresh and the m3u file get updated.
I have tried with update in the menu of mol2 but the the channels or VOD don’t get updated.
Tanks for quick reply. Now the epg is working again without change of settings. So it was a provider issue.
Yes. They say that it is probably a setting in mytvonline2. I have the same problem with app in mobile and and mi box so that it sound like it is a service provider issue.
I recently got the Formuler Z8 and what a great box. And mytvonline2 is great.
But after a few days the EPG want work. It seems like it’s not update. The EPG says “no information. “
I got an EPG URL that has worked before.
