Thanks!
I got a M3U-playlist and added that. Now it seems to work and a new portal has been created with username and password. My vod-movies also work so far. Thank you so much for all the help.
Thanks!
Do I still use my mac/Id from the Z8 to the provider?
Can i still use mytv-online2 app?
Is it the same portal adress from provider if i use xc api, as I got with stalker?
Yes i will try that.
Thanks!
I got a stalker connection. With mac/id registrering.
Thanks so much for your help. I'm going to read there!
I'm not good at this and am not sure if I understand your question. But I have only entered a adress in the URL portal. That i got from my provider. No extra adress ore something for vod (IF you can have a seperat adress for that) only one adress.
This problem started a few months ago, after an update.
I have problem with VOD. If my box has been in standby, it can not load vod data, and there is an error message that it could not load vod. Then I have to reboot and then it works for some day again. Anyone else have the same problem or a solution?
