Posts by Minimeben
    On Mol3 when guide is selected and displayed on screen is there a way to enable left or long left on the remote so it displays the channel groups?
    I know we have a Groups button on the remote, so we already have a solution. However I'd like the option to press left or long left to display them as I'm always having to look at the remote to find the groups button and this I believe would make it more user friendly.
    As said in the title this is a question to see if it can be done already and if not a suggestion to see if it can be considered 🙏
    Evening all, I can see the disable / enable toggle has been added, however when I bought the Z11 Pro Max it was on the understanding that multiple playlist would be of use
    We are now quite a way since this was launched and I see lots of fixes / developments (like toggle) however non of these resolve the issue of having access to all services at the same time.
    Do you have an eta on when this will be possible with the option of identifyingbwhich service is which without having to scroll through one huge list of channels folders?
    Hi All, been a while since I got this box and have to say the one long list if channels for the 5 services I have is a big problem.
    Even with hiding things I don't want to see the list is huge
    I know Sam said last year when the box was launched and this was mentioned as an issue that collapsible service name headers above each service was well received as a suggestion by the developers, but 2 months on its still a huge list and therefore still a big problem.
    Can Sam or anyone else please provide an update on when we can expect to see this change rolled out?
    It feels like it shouldn't be a big change to make, but the change it'll make to box owners will multiple playlists is huge.
    Hopefully something in the not so distant future?
    Just received my Z11 and noticed that the categories from both services are shown as one long list.
    Is there not a way in Mol 3 to have the provider detailed at the top and for that provider to be collapsible / expandable?
    Without this there's no way of knowing which service is which as most categories have the same headers from most suppliers.
    This looks to be a step in the right direction, but looks unfinished
    Do you have an update on this please.
    I really don't want to return this box, but the multi sub option as one huge list is just impossible to work with.
    Can you advise on when this will be fixed?
    Just simple, they are both connected (always) but full active only this one you watching Channel at current time + shown in the Category/Channel list. Change from Provider A to B is instantly. The Live TV OSD shows also the name (you inserted at creation) from used sub.
    Channel list-> first category-> test some channel (Is Provider A)
    Channel list-> last category-> test some channel (Is Provider B)
    In the List are all category`s shown from all active subs. but not with which category Provider B/C/D starts, this have you to found out.
    Hi All, just got my Z11 and wanted to see what apps people are using on there mobile to add their services via there mobile.
    I used to use Android TV app but that's no longer available.
    Is there a Formuler remote app for Android mobiles?
    Does anyone know if Mol3 gives you access to all services at the same time rather than having to come out of a service and switch to another.
    This for me would be the single biggest improvement they could make and I'd definately be purchasing if it had this functionality
    Love Mol2 but find myself using other apps because I want the ability to watch one service and record from another or when I search for something it return the results from all services rather than 1 service
