I haven't found any cases for the GTV-BT3 yet.
Posts by Monsterdog
I'd like to buy a black silicone cover for my BT3; where can I find one?
Do you know if there will be an update of the Android version planned for Z11 Pro Max?
Do you use VPN?
If so check your speed again when VPN turned off.
thanks, but no vpn, I think it's my formuler box that's faulty I tested at a friend's and I had the same problem with another internet provider.
I'm going to return it to amazon.
are you having speed issues, i have a 1gbit connection and i can't get more than 300mb/s since i formule zmini
I solved my problem by using a power supply of 2.5a that of the zmini only 1a output
I connected my [USB C Hub, ABLEWE] it does not detect the ethernet cable, is there anything else to do? THANKS
Solution !! I finally found
sorting mode on your Formular box. When you are in the movie list, it should say "Sort: Default" to the right of the magnifying glass. Click this button and choose to sort by new addition.
Good morning
It's weird with my formuler box even after a refresh no new film but on the Mytvonline app I have them?
I like mytvonline2 on my gtv ans also the gtv-bt1 remote control
Number 496
Will there be an update to Android tv 11 for the GTV in the future?
