zapping and long on the gtv.
Posts by mouss
I find that the application my tv online and along for the zapping and change of channel compared to the z8 or z8 pro from where the concern that is with afr activate or deactivate the zapping and long
yeah i've already tried aptoid tv too but no somersault on aptoid. good no big shame.
yes I have the mobile version but he would like an atv version better with the remote control
hello I wouldd like to have salto tv android tv version for z8 may I can not find?
yes me too I have some problems with the gtv. I like the gtv c a good box under Android tv. it has some faults to correct and it will be at the top I hope I have the z8 it and great so i prefer to wait for the fixes to come in a short time but i find it odd that we do not have all the same concerns everyone has these particular concerns so that c the same box.
I do not think that it comes from your box because I too have this concern as soon as I start to touch the bizarre z8 image adjustment all the regale passes no problem
ok thanks i will watch her closely
Hello why when I pass my z8 in ycbr 420 10bit he goes back to 444 8bit after and doesn't move anymore?
Please make a video of the issue using your smartphone and upload the video to https://streamable.com
Please make sure to show your fingers pressing the remote buttons and the lag on the tv screen in the video.
After that, use the chatbot at https://support.formuler.tv to create a support ticket and someone will help you report the issue to the developers.
If you have difficulty, PM me (conversation) here on the forums.
ok no worries i will do that it happens on my lg oled tv when i switch to a vod or a channel which broadcasts 24fps or some time on 60fps on the 50 is no problem.
The developers are aware of the slow-down issue. Please try the next software update to see if it fixes your problem.
hello should we reinitialize the box after the small beta update because it does not solve my problem of lag?
ok thank you I hope that will solve the problem.
when will the next update be?
no but I have a z8 and a gtv with the same supplier same url on the z8 no problem on gtv there is the problem. before posting a problem I do the check and sorry if I report any real problem to improve the gtv because it has a lot to catch up with compared to the z8.
hello why at certain moment i have a black screen on the channels and it goes back a few seconds two or 3 times and after its walking normally?
if we but on 50htz we have to remove the afr
Hello and for the slowing down of the gtv with certain users, I don't pence everyone but there are some people who complain about slowing down and afr bug which makes the gtv slow down afterwards I do not see where the problem comes from. -
yes of course I can deactivate the afr but that will not solve the problem I find the gtv super May since the update of June I have this problem of afr bug and slowing down. but I do not want to deactivate the afr otherwise I have jerks if I go to 24fps or 60.
frankly I also regret some bug it often blocks
yes yes indeed me too I have the impression that the fps is kidding on a certain frequency image.on the z8 the parameters mto its in 50fps on all the application whereas on gtv c 60fps I pence that the bug comes from the but to be confirmed
desactivate afr auto
Why don't I see the hls?
hello I have problem of slowing down at certain times having to turn off the gtv and turn it on again so that it works since the update even after reinitialization always the same problem and it does not come from my internet connection because it works very good fiber on my z8.
hello I have just made the update for the moment ras it solves a lot of concern. Thank you Sam and good luck for the future.
I understand you, but there are reason why this time is closed beta.
thank you for your answer SAM. good hope that the public beta will arrive soon.
pity when can not all test.
hello how much more time of patience its become long 6 months and always the same problem on the chains full hd still how much time before before the release of this famous update?
Thank you SAM our z8 will no longer be DRM L1 in the future. he will only have the new certified formulators.
hello I have a formulate z8 all the updates are made but I do not have it still remains DRM L3 I have downloaded DRM INFO and it tells me that I am in DRM L3.
hello everyone
I am following a problem on my AFR gtv when AFR activate I have image slowing on some full hd channel but not on hd nor hevc only on full hd so I have to deactivate AFR auto it does not not from my supplier because it works very well on my z8.
bonjour j'ai un formuler z8 et un formuler gtv sur le z8 rien a dire mais sur le gtv lorsque je suis sur une chaine hevc et que j'eteint mon gvt et le ralume j'un ecrant vert sur le z8 aucun souci?
j ai aussi quelque problème de fluidité sur les chaine full hd je suis en fibre j ai l impression que cela vien de l AFR sur le z8 jd n ai aucun souci.merci
she and super fast which bothers me a bit c the image quality I do not know if it comes especially obvious on full hd.
No I have a z7 + a z8 and the gtv may I find the image quality to be good as the z7 + and z8 c my personal opinion hoping that formulate will release a new update to solve this problem.
I currently have a z8 and I have just acquired a formuler gtv to my great disappointment the image quality of gtv and bad with any setting nothing changes full hd quality medicre I do not understand yet the z8 has a quality super impressive image. pity I wonder if I will send it back disappointed.
