Experiencing the same issue, setting EPG to UTC doesn't solve the problem for me.
When I set EPG offset to 0 and EPG to normal, EPG data in the 'Guide' mode and the EPG channel mode (press "Right" when the info bar is visible) the times are correct. However, when I switch channel, press 'INFO' or press "OK" on the remote control, the program info differs 2 hours from the EPG.
Tried several offset settings (Normal, UTC, several offset values), cleared EPG cache, then (after the EPG data is loaded again) I get various results:
EPG Normal:
EPG Guide OK, EPG Info OK, Info -2hr
EPG UTC:
EPG UTC, offset +2hr:
EPG Guide OK, EPG Info +2hr, Info OK
There seems to be a difference between the EPG of a channel, the EPG in the Guide and the Info (program info in channel list and program info in the info bar).
I have 2x GTV's where this phenomenon occurs.
Any way to fix this?
Latest updates are installed, current versions:
Firmware v10.0.15
IPTV v10.0.17
Service v10.0.15
Tuner v10.0.17
Storage v10.0.15
Thanks in advance!
