deos this support 4K?
Posts by shy
Conclusion:
GTV doesn’t permit to write on USB connected storage, instead seems it has “read only” permissions.
I have connected my external Hard Disk on USB of Broadband router and Enabled SMB which I can access from GTV
same time I have Enable ftp too which makes very easy to copy media contents from any PC on network.
Additional Info:
Even I am unable to copy anything using any of explorer from Device Internal Memory to External Hard disk in both “ Device Storage” and “Removable Storage” modes
Dear All,
I have tried different File explorer which comes with Built in “Wi-Fi File Transfer” and “FTP server” option, I can copy/upload to internal storage of GTV however uploading to External Hard disk always fails.
I have tried External Hard disk in both mode as “ Device Storage” and “Removable Storage”
Kindly help.
Use app "File Commander" from Google Play Store on your GTV
Hi Thanks for reply
let me elobarte.
I dont want file commander to conenct to any ftp.
i want GTV to have a an option (e.g. act as a FTP sever) so i could access it from PC and simply copy my contenst to it.
Dear Support, Good day
I have recently bought the GTV and am fully satisfied with the performance.
I’m returning user from other Linux receiver and was using an external 500GB hard disk as Media Storage.
I have attached the Hard Disk with GTV as “Removable Storage” and it is working.
I want to know how I can copy my media files (Movies, Music) via ftp or any other means to hard disk.
Removing Hard disk copy the data and re-attach with GTV is not practical.
I got fed up with the limited configuration possibilities (and commercials) when using the Youtube app.
I found an alternative Android TV app that works great on my Formuler GTV, it is called SmartTubeNext.
https://github.com/yuliskov/SmartTubeNext
Haven't tried it on my Z8 Pro yet.
Hi May I knwo how to install on GTV?
Many Thanks.
