Posts by bmiller
    I ended up dumping Netflix for now. The problems started about a month ago. I would try it early in the day to check the video quality, and it would be ok. In the evening the video was so bad, it was unwatchable. No buffering, but the home screen was slow to load, the video was blocky, more like 180p. This was on an Amazon Fire Stick, ipad, Amazon TV 4K, and Mac. Every other service played in HD no problem anytime. This is a reported problem all over the internet. I have a 350mbps service and can play HD video from Prime, Appletv+, Disney+, Youtube, and Crave tv on multiple devices at the same time with no issue. Netflix is a mess right now. Their servers must be overloaded and need some attention.
    I'll revisit Netflix sometime in the future. Maybe by then, Netflix will certify Formuler.
    Netflix on my z10 Pro stopped working. Downloaded from the market place, without the update. Interface old and remote barely works enough to navigate. Tried sideloading numerous versions, to no avail. Downloaded the ninja.4 apk file, which turns out to be like the original install, but the same problem.
    Moving on from my new Formuler until this is fixed. Not a good look, as Netflix works on every other device and tv i've run across. I'll keep it around until this is resolved.
    New to Formuler. I just purchased a z10 pro, and have IPTV setup, along with prime Netflix etc. I've been looking through the settings for audio passthrough, but have found nothing stated as such. I'm connected from the z10 directly to a Yamaha receiver, and then to the TV. My receiver only shows PCM audio while watching Netfix and Prime 5.1 DD audio. There isn't any direction or manual for the z10 that i can find, and am hoping someone can clarify this problem.
