The sever is back on.
Posts by oldexonian
opensubtitles.org appears to be recommending opensubtitles.com, maybe this is why the embeded .org in Mytv2 is not functioning.
I have made a new log in for .com but Mytv2 does not recognise it.
Is this a work in progress for an update.
contacted my provider and they said they would notify Formular and maybe corrected on next update.
Just had an update but still the same.
I know not everybody is deaf but subs are a life line.
Thanks for your comments but I did try that and also made a second subtitles account but no joy.
Try the Shetland tv series. If I am able to watch live I can get the subs and if I am out can get the subs on catchup.
If I miss that and try the embeded prog on MyTV and get no subs.
Thanks for your time.
Yes I tried that but the result is the same.
This used to work perfectly for me as I am almost deaf and this was a great feature for me.
However since one of the updates it no longer works. I go through everything as before but when I ask it to find the subtitle it
tells me there are no subs available. If I leave MyTVonline and go on the web opensubs shows subtitles which MyTV says there are non.
If I do a factory reset, will this cure the problem?
Thanks.
Thanks.
