ok i will try, i did suspect that because an other server works correct
Posts by Wolf50
No, i did that allready but then the channel epg is correct and the guide epg is off by two hours
Thanks for your reaction, Still there is a differents of two hours between the channel epg en the guide epg
Hello im new to this so i post a question.
i have a formules z10 pro max and when i look at the epg then it is not correct.
when i pres the right button is see the epg guide thats correct.
how can i change it so they are both correct?
Wolf
