Is there a solution for this already?
Since yesterday we also have this message. None of the channels work anymore.
Display MoreNo need to factory reset. Try this…
Settings
Apps
See all apps
Systems apps
Select “Android TV Remote Service”
Select “Uninstall Updates” and OK
Back out of the menus and it will work again for the Z10.
I have to do this once in a while when the Z10 disappears from the iOS app.
Do i have to do this on the Formuler or on the IPhone?
Did you check if there is new firmware update available for your TV?
Yes I did, but there is no update.
In the bedroom I have a third TV, an older one. It doesn't cause any problems here.
Now it comes, I bought a Formuler Z10 PRO, I connected this to the TV's that had problems and it does NOT give any problems with the HDMI CEC.
So the problem is really in the Formular Z8. It's a shame that I now have 2 of those rather expensive devices that don't work well.
Changed hdmi cable for a 2.1 version. Same problem.
The issue is on Tv side or HDMI cable if that not recognise the connected hdmi port with z8. Change hdmi cable and hdmi port, test again.
Thank you for your reply.
But if I start the TV 2x it works, could this also be the cable?
The Formuler Z8 also turns on (white light) but it just doesn't do anything.
Which cable should be the best? What should I pay attention to?
I have 2x Formuler Z8s.
I have HDMI-CEC turned on on all TVs and have it enabled on the Z8 as well.
There is only a problem:
When I start the TV, the Formuler Z8 also starts (white light), but the TV indicates that it is not on. Then I turn off the TV and Formuler again, start it again and then it works.
He does this regularly with both televisions. 1 is a Samsung TV, the other is a Sony TV.
Is this a known issue? And can this be solved? It is very annoying to have to start the TV twice every time.
Greetingz, Rob
