Thanks for he clarification
Posts by Boo_Productions
With the introduction of Z11 with MOL3, taking that the spec of the Z10Pro max is as good as the Z11 will the Z10Pro max be able to update to Andriod 11 and will it be able to download MOL3
Can a one suggest a reliable source where I can purchase a Z10pro in the UK
Hi Sam
Found the setting increased as suggested and all working well Thank you
Hi
I am on a Z10Pro, FW v10.10.27 - FR r26940
When I go into the catch up menu and select a programme to watch say from yesterday, I press play and start watching but then after a short while it starts to pauses / buffers and keeps doing this.
It happens with SD or HD programmes.
My wifi speed is tested at 60mbs and if I then go into normal TV no pausing or buffering.
Is this a known fault
Bo
Thank you for that. I have tried and downloaded a copy from that site, located it on my recording drive via media browser. All seems to install okay, my vpn is set to UK. I get a Britbox icon on the dashboard but when i execute programme it flashed blank then returns to dashboard.
Hi All
I am trying to load Britbox on my Z10.
As its not in market I have been advised to find a APK and side load it. I have downloaded a apk and install but nothing happens.
I have opened a browser and gone to
BritBox by BBC & ITV – Apps on Google Play
but get the message Formuler Z10 Pro This item is not compatible with your device.
Any help gratefully received. Bo
