Anyone know how to solve this issue, usually take the fire stick away on holiday but took the mini this time, tried connecting 2 iPhone hotspots and it keeps coming up IP configuration failure, a bit lost on what to try cheers
Posts by Shaynemair
Which brand is the TV?
It’s LG, the ball tracing is much better not just the ball goes blurry, which would rather have then 3 balls on the screen
So see this auto frame rate should this put it to 50fps? The channel is literally called Bt sport 1 50fps but using the info button it’s only 25, most other channels say 1080i
I’ll try the top option later tonight I played about with all settings seems better but still not great, probably just the streams
Not sure if you can reply to this, only supplier I’ve known for last 5 years is current one, would be good to trial one elsewhere to see the differences I have no idea where I would find another one any ideas if you can?
Okay mate cheers I’ve played about and it’s much better, I don’t think my provider saying 50fps on the channel but it actually being 25 helps..
Just recently bought a new 75 tv and the quality on forumler z8 pro is terrible the motion with the ball is horrendous also ball disappears when it gets kicked, I used the exact same settings on box when using a 58 tv and I can’t say I noticed issues (maybe just because it was smaller)
I’ve read some calibration settings to try, is the motion settings normally as default set as on? I didn’t even know there was this menu rather than the basic display menu on the box itself, there also seems to be a slight stutter on this tv, as far as I remember the top setting on display settings says 1080i and resolution is set at auto which is 4k 60fps
Any ideas on fixes? I have kind of ruled out it being the tv, as when I went onto YouTube through the tv and watched a 4k game the motion on the ball was absolutely fine, any tips appreciated cheers, played about with tv settings and some did improve it but then made other areas worse
500mb internet, hdmi 2.1 cables (I understand won’t be 2.1 quality)
