Posts by badmaniak
Always use the latest version of the official software if possible. There are no official sources for "old versions" of software. Anything you download from random websites has the possibility of containing malware, ransomware, or viruses.
Please share a photo of this message.
Possible workaround:
Enable Private DNS on your Z10 and set the provider to Quad9 or Cloudflare.
- Android Settings
- Network & Internet
- Private DNS
- Private DNS provider hostname
- Select one.one.one.one
After that, try the software update app again to see if you can access the latest firmware (v10.10.30)
The old versions were on the market of the Formuler store, ok i tried to change my DNS, with 1.1.1.1 and 8.8.4.4, but after the reboot and i try the software update, I'm still in the same version for firmware 10.10.2, while mytvonline2 is in 10.10.31!!
I have internet, the network configuration is good, Youtube working well
Go to Software update app on home screen and check if you can update the firmware.
Take a screenshot and post it here if you can't.
I don't update the firmware.
And on Mytvonline2 i have all time this message
I turn in loop since two days, with hard and soft reset, nothing makes it, is that the box has a problem
Frankly I did not think to have such problems with a box Formulate
Hello, I just bought a Formuler Z10 Pro, but with the latest update the Mytvonline2 application asks me to update, even though it already has the latest version and the Formuler is updated too.
Current Firmware version : 10.0.2
Current IPTV version : 10.10.31
I already did a soft and hard reset of the Formuler, I tried to install the old versions of Mytvonline2 even after a reset, still the same problem, the application asks me: "Attention please update latest software
I have not found a similar topic on the forum with a solution, if so thank you for directing me to them, otherwise thank you in advance for those who will answer me.
Regards,
badmaniak.
