Posts by Joaquin
Now Netfix tells me that it is not available on this device.
YES it has been the IPV6 solution.
Good afternoon .
I changed the Formulator to another router.
Wifi (2.4G) connection without internet
Wifi (5G) connection without internet.
PC and mobile connect with Wifi without problem.
I remind you that this formular was purchased in Switzerland, there it worked perfectly with and without IPTV.
IPTV ended subscription in August 2023.
and now he is in Spain.
youtube doesn't work
yes
Code
The formular z10 pro max was purchased in Switzerland. 1st direct by cable to the router 2nd yes, a yellow triangle 3ºI don't have a VPN in Switzerland or in Spain. 4ºIPTV ended in August 2023, now I only want the Netflix app 5º the Formuler has been factory reset 6th I don't agree to configure the Google account. 7th I can't update (v10.10.46) 8th DHCP -
SAM completes the process, updates the Formuler, everything is perfect.
Thank you
Sam thanks for answering
I don't know which of the three options is correct
step to click on Automatic (DHCP)
I continue with the configuration
Thank you.
Hello .
Formuler z 10 pro max query
The guides consulted do not solve my problem.
Steps done.
1st Spanish language. okay
2nd internet connection, password OK
Query.
3rd configure wired network>jump
Automatic(DHCP)
Manual
Which option is correct?
Greetings .
