i use mac on the one i cant add the one that works i conect without mac tell me how to add portal i go to mol3 and there are no placce for me to add portals
Mol3 Menu > Content Manager > Content sources
1. Different results in two EPG types - How many portals and what type of connection is/are your portals? MAC Stalker or XCI? Check it Menu > Content Manager > Content sources.
2. Switching sound - Does the click sound when switching from VOD to Live happen everytime? Connect your box directly to your TV and check if it happens again.
3. Skipping pictures switching to Live TV - Check the channel fps by clicking Info button on your remote twice. Does the issue happen everytime with the same AFR settings?
Turn all AFRs off and see if the skipping picture issue remains. Turn off the VOD AFR and repeat the previous steps and see if the skipping issue remains. daisy
I really hope it is software related.
And not some bad capicitors or something.
Don't forget my first question about the two hours time shift in the two different EPG screens.
Thx, for the video. You mean this click? does it come from TV, AVR or Soundbar?
Connected to Denon AVC-X6500H with HDMI. Comes from the speakers. My Z10 didn't do this, so it must be the Z11. It's connected the excact same way, with the same cabeling. Yes, it's a terrible click. it's difficult to describe....
Please make Video + Audio when you have time, is for the devs. Thank you
Loudness changes with volume.
Sam, i uploaded an audio file renamed to jpg. If possible, download and rename to mp3. First bit you hear is the vod movie then silent going back to live tv. Picture of live tv is already present, then this "switching" sound (at about 28 sec) in the speakers and normal playback starts. This is not always. You can do this 3 times and nothing will happen and the 3 times in a row. So it is random. Sound is a bit different than reality. Sorry for that.
This happens with AFR on. Would for now turn it off.
Sam, i already did that. didn't help.
Thx, for reporting. Could you please tell me which protocol is in use? Will try asap to reproduce and come back to you.
I think you mean Content Manager > Content sources > the Xtream code.
Als switching the box on and live tv starts playing makes a short sound in the speakers which shouldn't be there.
No problem here...... Everything opens fine.
I just bought a Z10 Pro Max. I can still return it for free and change it to a Z11 Pro Max, which will come next week. Maybe it's a stupid Question. ![]()
Is this worth doing? I just need to press the "return" button. Please help me decide........
Sam, thank you for your answer!
If i put the buffer time on 3 or 4 sec, i see an improvement of picture stability, but no changes in audio sync. Still in sync for a few seconds, then small picture skip and out of sync.
My internet is glass fiber 200 mbit up/down. My audio Cabinet, has a switch, NETGEAR ProSAFE managed Plus Switch - GS108E. It supports IGMP Snooping. They say this helps with IPTV? My box is connected to this switch.
What player next to MyTVOnline, would be the best, to play and test files from NAS? I have only experience with Kodi op HTPC.
i noticed with my Z10, that when the front of the box is visable and the extender is plugged in the remote doesn't work as it should.
1. Is the extender plugged in completely?
2. Cover the front of the Z10 so that the box itself can not receive an ir signal and try again.
