Hi Daisy, Just wanted to enable it because i thought you could. Thanks for getting back to me. cheers all the best.... ![]()
Posts by muttleytheplug
Hi can anyone help me enable developer options on the z8 pro. i press ok 7 times on the build options but nothing happens!. Any help would be great thank you..
Does anyone no how to remove a config file from mytvonline2?, my old supplier gave the method to me so i didn't need to use a portal address, just username and password.
i want to restore it to default so i can use a portal address again. i have tried factory reset but it still comes up with add ng user when i go into the app!. i would be grateful for any help. thank you.
