Posts by zutt
    There might be a problem with connectivity. VPN is not being used.
    On fast.com, I get 990 Mbps on my desktop computer.
    Formular app reaches 360 mbps. That's 2.75 times less. On the formuler, the network card should be 1Gbit.
    The two devices are connected to the same switch and are 1 meter apart.
    What debugging suggestions do you have?
    Recently, I purchased two Z10 Pro Max. In order to not use the TV's CPU / memory, I thought it would be a good idea to have a dedicated box for streaming.
    I have downloaded and streamed movies from HBO Max, YouTube and the Danish television app DR TV. The video is lagging heavily on all of them. The experience is not enjoyable at all. I would rather watch from the TV apps instead.
    Tivimate's streaming IPTV, however, appears to work fine.
    Both boxes on two different televisions are affected by this.
    Firmware: 10.10.41
    IPTV Version: 10.10.44
    Network: 50 Mbps according to fast.com and analiti wifi analyzer
    Any suggestions ?
    Cheers
