Posts by A1St0
    I would like to see the ability to turn off the white power LED in the system settings. My old WD-TV player (gen. 3) had the following settings for this (from the User Manual):
    :exclamation_mark: "LED Light Control
    Use this menu to turn off the WD LED light (Always Off). If turned off, the WD LED
    will only appear during start up then disappear after the device has booted up. The
    default setting is (Normal)."
    :exclamation_mark: You could also do it with three settings:
    Note: Standby is only affected in the third setting - otherwise as it is now.
    *) always on
    *) on until booted up
    *) always off (also in standby)
    Thank you very much!
    ps:
    A good example of a company that has thought about this aspect!
    Whether a WiFi router/node or a monitor, they give you the option to turn off the (LED) lighting.
    :waving_hand: :smiling_face: Hello!
    With this message I turn to the developers of the firmware from the almost perfect TV box.
    A few words beforehand, it may not affect everyone and not everyone will find the lack of the desired feature a disadvantage. I also don't need any hints on how else to get around it (tape etc). It is a personal feeling and please accept it that way.
    I would like to see the ability to turn off the white power LED in the system settings. All my old WD-TV players (all generations) had the following settings for this (from the User Manual):
    "LED Light Control
    *) always on
    Otherwise, I can fully recommend the box and I hope that this shortcoming is still fixed - thanks for the support! :folded_hands:
